Re: Need an opinion
Posted by Doug - Iowa on October 05, 2009 at 11:37:17 from (97.64.139.194):
In Reply to: Need an opinion posted by Gary Hutchinson on October 05, 2009 at 11:08:40:
You're on the right track but your math is a bit off. Remember you are dealing with volume so you need to calculate the area of the piston and then compare the volume. For instance, your 4" dia cylinder has a piston area of 12.57 sq.in. so it will reguire 12.57 cubic inches volume per inch of stroke. A 2" dia has 3.14 cubic inches volume per inch of stroke. To halve the volume you probably would be better with a 3" cylinder giving you 7.07 cu in per inch per cylinder.
This site makes the math easier...
http://www.surpluscenter.com/Hydraulic.htm
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
