That 20-40 is weak for sure. As stated, the pressure relief is in the oil filter base. Or I should say the second relief is in the base. There are two. The oil pump has one that goes to about 75 or so, and the filter has another, set to the lower 38-46 psi prescribed value.
There is a large shallow bolt head on the filter base. Remove it and the spring/piston come out. Or should anyways. It may be, and probably is, stuck. IH did not use a ball valve. They are both piston types, with a clearance spec of only a few thousandths. Any, and I mean ANY, crud will cause the piston to stick. Normally they stick open because the spring don't have enough oomph to push it closed with grit trying to slip down past the piston. On the other hand, there is enough surface area on the piston that a little corrosion will stick it, causing high pressure. Also, somebody may have shimmed the bugger tight?
The pump regulator bypasses back into the pan. The filter regulator also bypasses back into the pan.
I haven't checked my MD, but later model crawler filters have a bypass valve as well. All it does is allow oil around the filter.
This post was edited by M Diesel at 15:14:38 10/08/09.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
