Posted by jimb2 on October 09, 2009 at 16:17:31 from (99.240.236.11):
In Reply to: Hyd Pressure posted by DrEd on October 09, 2009 at 09:10:09:
Hi, the 424 has one hydraulic pump with a flow divider controling the rate of flow for power steering and 3pt. The hydraulic filter is on the return hydraulic return line in the hydraulic housing to right rear of gear shift lever. There is also a hydraulic pressure relieve valve in the hydraulic housing under the seat. It is difficult to diagnose your problem but some things to consider: 1)Has the hydraulic filter been cleaned recently? 2)Does the power steering work OK?
Could be a worn pump but if power steering works OK then possibly be faulty priority valve or pressure relief valve. You will require a hydraulic flow and pressure guages to diagnose the problem.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
