Center 1 inch pin that holds the wishbone [one in the front axle casting] is held in with a roll pin. Drive roll pin out & pin should fall out. When putting this pin back, have an assortment of 1 inch washers on hand to shim up the empty space between wishbone & axle casting. Get as little slack as you can in this area. The bushings are straight forward--use a hacksaw to cut through the 1 inch bushings [remove blade from saw & insert it through the bushings & then reassemble blade on hacksaw]. On the large steering cylinder bushings, use a small chisel to cut through them. Could probably use a die grinder also.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
