As Brownie, I want to know if it is in the metal, or at the gasket/bolts. Either way the plate needs to be cleaned primered and painted. If the leak is in a surface, it needs to be brazed to cover the rust pits (inside is least visible). Your coolant should prevent rust, so make sure it has Coolant mix (50/50 with clean water). Do not leave plain water in it, you will have rusting on internal parts and high regrets. Jim.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
