With it running 2/3 throttle, Ground the F terminal (either at the gen or regulator. The amp meter should go to charge (even with a full charge in the battery) If it does not, the cutout relay in the VR is not closing, or the Generator has issues. If it does not charge, leave the F grounded, and use a piece of insulated 10 gauge solid copper wire to jump between the VR's BAT marked terminal (recently found to be so marked) and the Unmarked terminal now connected to the Arm. This should spark, but it should be charging well into the meter range. If not , the gen is needing to be tested at the store, because you have just bypassed the entire internals of the regulator and it is still not charging. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
