You may as well unbolt the input shaft bearing cage and pull it out the front of transmission. Then you can check it out including piliot bearing. Will make it better to remove the bearing from input shaft and see if the bearing cage is bad and also check the rear bearing on input shaft. If the bearing just spins in the cage but is not loose enough to have play, when the bearing retainer with seal is bolted on it may keep the bearing from spinning.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
