Posted by CNKS on October 15, 2009 at 09:02:52 from (216.144.104.128):
In Reply to: Super A hydrolic leak posted by JD in B.C. on October 15, 2009 at 07:55:13:
The front engine seal and the one on your pump are not related. You need to replace the pump seal, and the engine seal too. I suppose a higher oil level would cause a bigger leak, but if the oil is an external leak, it will continue leaking after the pump is fixed. Take the pump off and look at it, the repair is pretty much self-explanatory. If the seal is an oring, you will need to have the shaft hole enlarged to accept the speedi sleeve.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
