Posted by oldtractorsrock on October 15, 2009 at 16:53:21 from (74.67.151.205):
In Reply to: Diode Question posted by Pete7 on October 15, 2009 at 16:32:37:
I"m not sure about the radio shack diodes. Some gm (I think) cars used a push in diode for the ac clutch. This diode pushes in the fuse block and looks like a fuse except it is marked "diode". These should be available in most auto stores. They have blade terminals so you can use crimp terminals and they are pretty rugged.
Another option is if your starter or relay has a "I" terminal. This terminal is energized only when cranking and is seperate from everything else. I"ve used this method successfully several times.
Yet another option is a single wire alternator. This is my personal preference. They can be usually be found at Autozone for about $50. I have these on two of my tractors and they work greatand are easy to wire, 1 wire from alternator to battery is all you need.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
