Tension from the centering spring on the lever control mechanism and the spring in drive selector valve holds lever against side of quadrant. That is about it. It should take some amount of effort to move lever side to side from both springs. In transmission itself all you are moving is a cam plate and it is pretty well balanced. I will throw this in. That cable operated mechanism is not nearly as nice as the old rod type of earlier model tractors. So many spots to get sloppy. You may take a look to see if someone has added a return spring to keep all the free movement in one direction and that would possibly make your lever creep more. Just follow up where the cable operates the valve .
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
