Posted by pete 23 on October 20, 2009 at 11:38:32 from (173.87.147.73):
In Reply to: 756D posted by Icuby on October 20, 2009 at 10:45:27:
I am going on the assumption this oil pump is the externally mounted one normally used on a D-310 in a 756. Some applications used a internal pump with this engine. There are two styles of pressure relief valves, 756 should have late style. Just be real sure you used correct replacement spring, I am not 100 percent sure but I think the old one piece relief valve plunger used a stronger , longer spring. If you still have the old one try it and make sure the two plungers are installed correctly. Your oil pressure is way to high for that engine. Another thing on these engines. You have to be doubly sure you have correct oil filter. It needs the one with bypass valve in the filter. The filter for 400 series engines will screw right on also and it does not have bypass in it as it is in the base on those models.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
