Re: W-9 Carb
Posted by M Diesel on October 20, 2009 at 12:47:30 from (12.24.61.12):
In Reply to: W-9 Carb posted by ddownum on October 15, 2009 at 11:12:21:
Hmm. Does the manifold match in size? Does it have an IH part number?
Obviously parts can be swapped but it may require the manifold as well.
Assuming it is original...
It may be a factory arrangement as power units had a lot of engineering tweaks done to them for various reasons. For example, the IH diesel injection pump books are full of variations in settings and governor parts of which almost all are related to power units operating at different speeds and loads.
A larger carb would have been used on a machine that is expected to run fairly well loaded at full RPM all the time. Efficiency under those circumstances would be more important than the ability to provide power at low RPMs or smoothness of idle. A tractor would be optimized for peak efficiency somewhere in the 60% speed/power range and is expected to run nicely across the speed range, while power units typically have only two positions, IDLE and RUN.
It won't necessarily run better at all, but will consume more fuel under light loads due to fuel dispersement problems caused by the drop in velocity.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
