Posted by Mike CA on October 25, 2009 at 14:54:50 from (99.28.152.102):
Upon suggestion from this thread: http://ytforums.ytmag.com/viewtopic.php?t=548514 I turned the bracket upside down to see how that will affect my genny belt replacement. Here is what I found, please offer suggestions...
The bottom bracket, as you may know, has it's holes off-set. So when I flipped it, it pulled the genny back. That pulled the belt out of alignment, as shown here:
The flipped bracket also raised the genny, which put the belt very, very close to the bottom of the water pump, as seen in these 2 pics:
With the bracket flipped back, how I originally intended, you can see the clearance under the hood. But if I stretch it out to tension the belt, I get awfully close to the side of the hood. It may even hit. Hard to tell without the radiator on.
So, I'm not sure what to do. Buying a new belt may be expensive. I could drill out new holes in the bottom bracket to pull the genny forward to align it with the engine pulley, but I don't know if it will clear that water pump enough. I can only hope that it does.
What do you all think I should do at this point?
Oh, and a question was asked whether my genny pulley is adjustable... yes it is. When I tighten it, the slot for the belt has a larger diameter, tightening the belt.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
