Nebraska Kirk said: (quoted from post at 19:41:44 10/25/09) The clutch peddle and shaft on my 400 are worn bad too. I ordered a new shaft from A&I. I have yet to bore the hole in clutch peddle hole and install a bushing.
I should clairify: When PK was done you couldn't tell it had been done. Sleeve was pressed in and welded on each end then ground smooth. Hole was drilled through new sleeve for new grease fitting, which they also installed. Beautiful work. Highly recommend.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
