As CNKS said, just snug, but not tight enough to start distorting the gasket. If you see the gasket starting to bulge around the bolts you've gone a hair tight. Also you want to do one bolt on each side, kind of like torqueing a wheel down.
As to your stripped bolt, the only way to replace that aluminium piece is to split the tractor. So your easiest option is to repair the hole with a helicoil kit. You can probably find one at any decent auto parts place. Basically what you'll do is drill the hole out larger, tap it, and install a special insert that will restore the threads to their original dimension.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
