Re: SA Clutch adjustment
Posted by rustyfarmall on October 27, 2009 at 12:10:16 from (209.152.78.140):
In Reply to: SA Clutch adjustment posted by Dellbertt on October 27, 2009 at 11:51:32:
If there is too much free travel in the pedal, there could easily be a problem with the clutch not releasing completely, with resulting symptoms such as you describe. Free travel adjustment is just about the only thing that could be at fault unless you have a brand new clutch and pressure plate installed that was never set-up properly to start with.
Hugh would have told you to consult the manual. I will tell you the same thing.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
