Re: 806 Hydraulic draining/capacity
Posted by The tractor vet on October 27, 2009 at 16:48:53 from (75.19.126.148):
In Reply to: 806 Hydraulic draining/capacity posted by Thurston on October 27, 2009 at 16:25:43:
well the one drain plug for the rear end is up under the drawbar if ya have three point and you will have to drop the drawbar pin and and slide the drawbar back , Then there be two drain plugs one for each bull gear (they do not fill from the main fill hole and each has to be filled thru there own fill check plug located on the side and to the rear of the axles) . Then there are two drain plugs up under the center section . And ya might as well just get 5 five gallon buckets of Hy Tran and you will be just about wright with a little left over for later .
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
