The oil in the bull gears (final drive) is separate from the oil in the rear frame unless someone has updated the housings to the later style. The change was to drill holes in the rear frame so that the oil could run between the rear frame and the axle housings. If it is updated the check/fill plug on the axle housing should have been cut off so that it can not be removed to indicate the change was made on that side. Some tractors out there have only one side done.
If you lost the steering and the tractor will not move out of the field you most likely have more problems than changing the oil is going to cure. What other symptoms do you have? Was there a change in noise? Do the rear hydraulics work? Does the PTO work?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
