Idf it were me I would not use a harness for a magneto. If you use a wire harness for battery ignition there are only two changes you need to make.
1) Use an ignition switch for a magneto. You need to do this anyway no matter which harness you use. The wire from the switch to the magneto is the same as the wire from the switch to the ignition coil.
2) On the wire that is to run from the ammeter to the ignition switch, use tape to insulate the connector that is designed to connect to the ignition switch so it doesn't short on anything and tape it to the harness. If it is a separate wire it can be left in the light switch box.
With the battery ignition harness it is much easier to go back to battery ignition if you want to make the change in the future.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
