The issue may not be the key. If it will crank with the key in the start position, and will run (if it fires when the key is turned to run) in the run position, it may be OK. Most key switches maintain the ignition connection when starting because it is not a separate switching action. The ignition coil may not be firing while cranking because of low voltage to it. Low voltage can be caused by a weak battery. A set of too small battery cables (00gauge is needed, including ground strap) a out of spec ballast resistor (if it has one) a poor coil 12 v coil with no external resistor required used with a ballast resistor. or combination's of these issues. A 6 volt coil needs at least five volts when cranking (it will have an external resistor) a full 12v coil (No resistor required) needs at least 10 volts when cranking. A 12v coil that needs a resistor is just like a six volt coil in reality, and needs 5v at least when cranking. If there is voltage when cranking, it is the amount that is an issue. If none, it might be the key. Good luck, JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
