Head gasket problems are more associated with the diesel engines. Diesels have one less head bolt than the gas and have much higher compression.
In addition to making sure the head and block surfaces are true you also need to watch the sleeve protrusion from the top of the block. If I remember correctly the specification is for between 0.0 and .005 thousands above the block deck surface. Also you need to make sure there is no more that .002 difference between any two adjacent sleeves.
If you need to have the block deck resurfaced you also need to have the sleeve recesses remachined to get the sleeve protrusion correct.
I did have one 560 gas that I worked on where block deck and sleeve heights were bad but otherwise was in good shape. I was able to have the machine shop redeck the block without disassembling the lower end. They just machined the sleeves along with the block. If it ever needs to have new sleeves put in it in the future the sleeve recesses will have to be redone. It was sold on an auction about 15 years later so I don't know where that one ended up.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
