Re: ammeter needle bouncing
Posted by Owen Aaland on October 31, 2009 at 17:29:24 from (207.13.114.170):
In Reply to: ammeter needle bouncing posted by matt from WI on October 31, 2009 at 06:01:21:
The things that JimN suggested may take care of the problem or the bouncing needle may also be normal for your setup. The original ammeters were only 20 amp gauges. The alternator you installed is probably in the neighborhood of 60 to 75 amps. The regulator in the alternator does not hold a steady voltage but rather is always changing the field current from too high a voltage to too low and then back to too high. It keeps repeating this cycle. This slight variation in voltage causes the amperage output to be constantly changing. It may only vary an amp or two but it happens rapidly. The higher amperage output of the alternator and lower the capacity of the ammeter the more likely you are to see the needle movement.
Putting a capacitor across the terminals of the ammeter would serve as a dampener and should eliminate the bouncing needle. I don't know enough about electricity to know was size capacitor to suggest.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
