Posted by Wild Bill on November 01, 2009 at 20:47:40 from (208.44.160.51):
In Reply to: Clutch shaft on H posted by Janicholson on November 01, 2009 at 16:15:27:
FarmallBear said: (quoted from post at 17:15:27 11/01/09) I'm tryin to remove the clutch shaft on my H. I have disconnected the back side closest to the rearend at the U-joint resembling part, but I'm not sure where to disconnect it at on the front side. My tractor doesn't have the belly pump and to my understanding the shaft is different whether it has the belly pump or not. Is this correct? I'm having a hell of a time with this tractor, but I try to remain positive and very willing to learn as I go. I think its great how you guys read through the posts and help people through their projects.
Thank you,
Jeremy..
Jeremy, I just had mine out yesterday. If you are talking about the drive shaft, you need to take the coupler (u-joint) out completely. It will be two bolts on the shaft and two bolts on the trans input shaft. Once once you have the coupler out of the way, start wiggling and moving the shaft and it will come out. Make sure your trans is in neutral so you can move the input shaft to find a sweet spot that will allow you to pull the shaft down and out.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
