You didn't indicate where the post was tweaked (only how it was tweaked) so it is not possible to tell you exactly how to untweak it.
If the distortion is at the base flange, a come-a- long will do. If the damage is somewhere in the tube length, remove the column, and press or bang it out with a hammer and block of wood. Might want to cut a notch in the wood block to spread the impacts. Don't mess with the rivet. Motorcycle fork tube are spun in a lathe to check runout. But you haven't a lathe so don't worry about it. A straightedge will get you close enough.
You should straighten it. You might be surprised how a slight misalignment can affect the amount of effort required to turn the steering wheel. The misalignment causes the steering shaft and bearing to bind.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
