Posted by pete 23 on November 09, 2009 at 16:29:54 from (173.87.147.73):
In Reply to: 1086 injectors posted by jim dehoff on November 09, 2009 at 04:27:28:
First off, drain the coolant as the injection nozzles fit in a brass sleeve which is directly exposed to the coolant so if sleeve loosens you may end up with cyl full of coolant. Second, don't twist back and forth as this will only make them bind tighter. They should actually just pull out easily if top dirt seal and lower compression seal are good. Usually just a small rolling head bar will pop a tight one out but you may have to devise a puller. Before installing them clean sleeve good including the hole in bottom where tip extend into comb chamber and try fitting injector into sleeve with out the top seal to make sure it drops right into bottom on it's own weight. I have seen them where they leak combustion after installation due to the carbon build up in that hole and injector not bottoming out really easy. Torque clamping cap screw to only 12 ft lbs .
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
