If it uses a 12 volt battery Id buy a 12 volt starter (and see next Para.), but if it uses a 6 volt battery then I would buy a 6 volt starter.
NOTE its possible to run a 6 volt starter at 12 volts, although it can be a bit tough on centrifugal Bendix Inertia type starter drives, I have recommended use of a lighter 12 volt batetry in such cases with only like 500 to 600 CCA while our friend Bob M simply uses lighter battery and ground cables like a No 2
HOWEVER you cant hardly use a 12 volt starter with only 6 volts, she would crank tooooo slow if at all under a load
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
