H Model Charing trouble
Posted by VFMerc on November 15, 2009 at 06:22:18 from (98.110.125.83):
Thanks all;
I confirmed that the tractor is wired correctly and added a wire directly from the grounded (+) post of the battery to the generator and v/r base to ensure a good ground.
I also confirmed that I have hot battery voltage (6.2) to both terminals of the ammeter and the BAT terminal of the V/R. The ammeter swings to the discharge side when lights are turned on.
Based on what I learned from everyone's posting I confirmed the polarization of the generator.
I then started the tractor and took a reading at the "A" terminal of the generator which is wired to the "GEN" terminal on the underside of the regulator. With the tractor running the "A" terminal shows no voltage or a very small -0.13.
Having worked all the way though Bob T's troubleshooing guide I'm guessing that despite having taken the generator in to a repair station at the start of the process the absence of any voltage reading at the generator's "A" terminal means generator is not producing any current?
Before I take the generator off I'll double check the battery and make sure it can accept a charge (plates covered by distilled H2O with no milky appearance).
VFM
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
