Okay. It seems like you can follow wires alright. And from your descriptions, it sounds like you're set up for negative ground which suggests you're running 12v on an alternator???
If you don't see a solenoid anyplace in the works, check out the diagrams on the link below. BobM, who is around here a lot, has very kindly worked up some clear wiring diagrams and makes them available at the link. Check out #3 to begin with. It shows a saddle-mounted starter switch, but Bob notes that there might be a separate loop that the schematic doesn't show that would accommodate a remote starter switch.
If that isn't just it look around the others to see if one is a better fit.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
