Posted by D Slater on November 18, 2009 at 16:32:31 from (72.65.152.4):
In Reply to: Re: Super H or NOT? posted by low96hb on November 18, 2009 at 13:28:54:
The 2 numbers are on the clutch and transmission housings, 8276 DE is the transmission housing and could be on a H or some SH tractors. 8024 DE could be on a H or first type SH. For a H engine look above the tappet cover and below head level on right side of block, rear half for a 4 digit number followed by 2 letters. Should be raised cast letters and look like the numbers you posted. Later model or replacement engines will have 6 numbers followed by R1,2 etc. if not ground off. If you found a flat spot near right front of engine on the right side with a X stamped in its probably a H engine. Most H engines that were made to use gasoline fuel had a X1 after engine and chassis serial #. If you can manage to read the engine serial number it will be the same as the tractor serial #, provided the engine and tractor are original. If you look forward from the block casting # on right side of engine block, agian looking in the area between head level and tappet cover you should find a date code, raised cast numbers and letter. (Example 4-8-T) This will tell when block was cast. 4= april, 8= day, T= 1950. You should also find the engine firing order cast in the right side also.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
