You don't need a starter with a stud. All you need to do is jam the existing starter switch closed somehow.
Cut the wire running from the battery to the existing starter switch and solder on ends to fit the heavy lugs on the solenoid. Mount the solenoid somewhere convenient (under the platform) and make sure it has a good clean place to ground against. Connect the heavy cables to the lugs.
If the tractor has a magneto you have to leave the kill switch alone and use it like always. If it's got a distributor you can replace the ignition switch with the key switch.
There is probably a wire running from the starter switch to the ammeter. You need to relocate this wire to the post on the solenoid that connects to the battery. Otherwise, the lights won't work and the battery won't charge.
Mount the key switch. Run a wire from the alternator side of the ammeter to the +12V post on the key switch. If you have a distributor, you can simply remove the ignition switch and install the key switch in its place, and use the old wire from the ammeter to the ignition switch.
Run a wire from the S(tart) post on the key switch to the S(tart) post on the solenoid.
With a magneto, you're done. Pull out the kill switch, turn the key, and you're off to the races.
With a distributor, connect the wire from the coil to the I(gnition) post on the key switch. Now you're done.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
