Burrs on the clutch shaft spline can hang the disk hub rubbing against the FW. If some (extra) rough motion was needed to get it to mate when putting it together the hub can be bent causing it to drag on both the FW and PP. Was the TO bearing of the carbon style, or the regular Ball bearing? if Carbon, and worn down it might be not able to push far enough. There are pivot points and pins in the TO cross shaft that could be causing TO positioning problems. Were the new and old clutches the same !! There may be dramatic differences between the Rockford and IH clutch. Was the flywheel machined, and was the step in the FW set to factory spec? THis is the best I have. JimN
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
