John T said: (quoted from post at 16:30:02 11/21/09) I still cant say if you have a late Ford type solenoid or one like Janicholson mentioned????????
If its the late type AND IT WORKS and is grounded, when you apply 12 votls to the small S terminal THE OTHER LITTLE I TERMINAL IS SUPPOSED TO THEN GET HOT !!!!!!!!!!!!!! Its lil I terminal is (supposed to be) hot ONLY when the solenoid is energized with 12 volts on its S terminal...
A test lamp and multimeter is all you need to check out that solenoid, its NOT rocket science. if its NOT the late Ford type but needs a ground ALL BETS ARE OFF and if I know that then I will guide you different or just do as Jim already told you
John T
When the solenoid is installed, the I terminal will have power whenever the switch is on. The power will be coming from the wire, not from the solenoid.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
