Hi...From the pictures, it looks like your tractor had a fast hitch on it at one time. I say that because the rear rockshaft (picture 2)is the type used on the tractor with a Fast Hitch. If you want to hook up the loader to the tractors hydraulic system (instead of the front mount pump) you would need a by-pass block. Picture 4 shows the hydraulic manifold and what you call the box (Touch Control Unit). The by-pass block fits between the box and the manifold. The rod that connects the rear rockshaft to the front left rockshaft(on the box) came in at least two types. One type used a spring to help absorb shock and that type was used with the Fast Hitch system The other rod type was similiar but without a spring. I see both types on Ebay all the time. The right front rockshaft was used to lift implements like a snowplow, front cultivators or planter.So linkage depended on the implementbeing used. Do the steering arms actually rub the tires? Are the tires too big? Is the steering arm bent already? If the arm isn't bent, I would not heat or bend it. Pete
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
