Posted by Jim Becker on December 04, 2009 at 11:05:28 from (173.57.141.22):
In Reply to: IH 1000 Loader on SAV posted by Bud W on December 03, 2009 at 13:06:47:
That loader on a Farmall 140 is supposed to be able to reach 4.7 inches below ground with a level bucket. Not sure how much that would be reduced on a 140 High Clear. Bucket would certainly touch the ground when tipped down a bit.
I would be more concerned about stability. Loaders and high clearance tractors just aren't a combination you see. This may be more hazardous going to shows (loading/unloading) than in use. You could set the wheels wider but then you increase the risk of something breaking. The IH manual specifies limits on how wide to set wheels with the loader.
The front mounting bracket has to be modified to use with the heavy duty front axle. The same modification would be required on a high clear tractor.
You really need to get the manual for the loader before you try to mount it on anything. The tire settings, front bracket modification and hydraulic connections are all covered. You can get the manual from Binder.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
