Re: sleeve bores
Posted by pete 23 on December 05, 2009 at 20:35:54 from (173.87.147.73):
In Reply to: sleeve bores posted by Butch-Ia on December 05, 2009 at 05:49:36:
The bore size is stamped on block just above the oil filter base and it will read 1 or 2 or 3 and not letters. They are numbered in line front to rear. You can get sleeves that will fit a bore sized 1 or 2 or sleeves that will fit 2 or 3 supposedly. However, like previous poster said, they are to be a heavy press fit and you should use a installer plate that will limit their depth into bock, they are prone to crack if pressed in until they contact the flange on the sleeve. Oversize sleeves are available also in case they don't fit properly. Sleeving an engine is not always a piece of cake.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
