Posted by rustyfarmall on December 07, 2009 at 17:12:19 from (209.152.78.140):
In Reply to: 2 Bad gauges? posted by ih5088 on December 07, 2009 at 14:03:40:
Machine249 said: (quoted from post at 15:03:40 12/07/09) I need help with my fuel gauge. I have a new sending unit and have tried two differant gauges with the same result. Everything is wired correctly and all wires check out as far as current (no shorts). Every time I hook it up, no matter the float position, it will bury on full. I have checked the ground on the sending unit wire at the gauge with a test light and get very dim on empty and bright on full. Am I correct to assume that I have tested two gauges with the same problem? If so where can I get a new gauge. Thanks for any help.
Is the sending unit fully grounded? If the sending unit is installed in the tank, and the tank is mounted on the tractor, is the tank properly grounded to the tractor chassis? Somehow or other, that sending unit HAS to be grounded for proper function.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
