Re: Horsepower formulas
Posted by TractormanNC on December 07, 2009 at 18:27:02 from (209.42.180.136):
In Reply to: Horsepower formulas posted by LenNH on December 07, 2009 at 13:46:27:
Hey Red Mist,
This might be a little help.
matters not about the type of surface
matters not about type of weight
matters not about weight on tractor.
If it takes 2200 lbs to pull a 10000 lb block of stone along the ground at 3 MPH
or if it takes 2200lbs to pull a 90 ton freight train at 3 MPH, the horsepower is the SAME.
The speed and the number of pounds of pull are the ONLY numbers that go into the hp formula.
By the way for LenNH, I question your constant of 300. I get 375. Correct me if I am wrong.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
