zooeyhall said: (quoted from post at 18:39:44 12/10/09) This will be the third time the head and block mating surfaces will be smoothed-down.
Most of the time the block deck does not need to be surfaced. Surfaceing the block is a rather big job, naturally all the studs need to be removed (not an easy task) and after the deck has been surfaced the sleeve counter bore will have to be bored deeper to maintain the correct sleeve protrusion above the block.
I would not be worried about surfaceing the head for the third time unless it has previously been shaved down to gain more compression. Surfaceing usually removes a few thousandths of an inch, depending on how bad the head is warped.
Most overhaul kits come with connecting rod bushings, get your shop to install the new bushings and then ream/hone them to the correct size.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
