Posted by Wardner on December 10, 2009 at 20:31:47 from (4.154.247.3):
In Reply to: 450 tachometer posted by danto on December 10, 2009 at 19:13:14:
The centerline of the gear housing ID is not concentric with the OD of the housing. This allows for gear mesh adjustment. You will notice that the aluminum (or pot metal housing) has scallops. The housing should be rotated until the gear lash is minimal. When you like the fit, install the two screws to secure the housing.
It has been awhile since I have done this but I think the info is basically correct. Earlier tach drives did not have the adjusting feature. It is also possible that the gear and shaft are so worn that proper mesh cannot be achieved or the gear is stripped.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
