Posted by Chris NW Ind on December 15, 2009 at 02:53:11 from (64.136.26.230):
In Reply to: w9 camshaft change posted by gpa rick on December 14, 2009 at 16:58:03:
I did the very same job over a year ago. Pull the radiator, valve cover, pushrods, lifters, oil pan and pump. Unscrew the big nut on the pulley and tap it off from behind (tap as close to the crank as possible). Jack the engine up a tiny bit to remove the front mount and remove the front cover. Unbolt the front camshaft retainer thru the gear and carefully slide the camshaft and gear assembly out.
What is wrong with your camshaft? I suspect mine was slightly bent, creating a terrible knocking noise at valve #3.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
