Posted by Owen Aaland on December 15, 2009 at 10:51:20 from (65.165.246.148):
In Reply to: 766 starter relay posted by rz1t0x on December 15, 2009 at 03:17:14:
The starter/solenoid can be checked with a test light. Engage the solenoid. Use the test light on the terminal that goes into the started. If the test light lights up the problem is in the starter, most likely worn brushes. If the light shows no power with the solenoid engaged the problem is the solenoid contacts, usually the one where the battery cable attaches.
A bad connection in the solenoid can often be corrected by removing the battery cable and loosening the nut that holds the stud to the cap. Unscrew the nut enough to be able to push the stud in and turn it a half turn and them reassemble.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
