Easy way to prove that the needle is sticking open: Remove the air cleaner from the carburetor and watch.
Things are probably gunked up enough that everything is sealed up tight and the fuel has nowhere to leak out. Thus, it can only get sucked into the engine.
Probably just a stuck float.
By the way, the worst thing that would've happened is the tractor would've caught fire from the fumes emanating from the gas that was on the tractor. No explosions. No engine blowing apart. There wasn't enough air in the engine to support an explosion with all that fuel in there. That's why the old girl wouldn't run... Even if you stuck a lit match in the spark plug hole, it wouldn't have exploded. The match would simply go out for lack of oxygen.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
