Posted by Pete7 on December 16, 2009 at 15:25:51 from (71.243.169.91):
Recently bought a Farmall 340 with a wide front axle (this is a row crop not the Utility) and started having trouble with the steering. You could turn the steering wheel but the tires would not turn unless the tractor was jacked up. With help from you guys I located a good used worm gear/shaft and matching wheel gear because I found the old ones were badly chipped and missing teeth. (tractor does have a loader on it) Thought that would solve the problem, right? Well, sort of, I can now turn the steering wheel and the tires turn ok, with the tractor jacked up. I don't feel any binding and it seems smooth thru the entire range, both running and not running while jacked up. But when I lower the tractor I can't turn the steering wheel. Doesn't matter if it's running or not, the steering wheel just won't turn more than a 1/4 turn or so. Shouldn't I be able to turn the steering wheel manually when the tractor isn't running? Do I have some thing binding the steering or is it a power steering issue? Pete
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
