Your points rubbing block needs to have one of the cam lobes directly under the rubbing block of your points. That's where and when you set the .020" point gap if you have a distributor.
You need to see if battery voltage is getting to the coil with the ignition switch on. Should have voltage on both small terminals with the points open. You need to use a volt meter set on DC volts or a test lite. If you have voltage on both terminals clean the points with some 320 wet or dry. Then pull one of your plug wires and have someone make an attempt to start the engine with the ignition swtich on and see if there's fire to your plug. Hal
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
