Most regulators are (or were when new) labeled to indicate voltage. They were also labeled for polarity, if it mattered. The marking may be stamped in or printed on. It is usually on one of the mounting brackets or somewhere on the bottom side. Most Delcos have it stamped into one of the mounting brackets. There will be some combination or 6 or 12, maybe a V and maybe a P or N. Maybe be POS or NEG. Might say "P 6V" or simply "12N".
There is a troubleshooting procedure on a web page. I don't have the pointer handy, but somebody usually posts it on any charging problem thread. I would expect a 6-volt regulator to test as "bad" if mounted on a 12-volt system.
One quick test is to directly ground the generator "F" terminal. Check voltage at the "A" terminal. This bypasses all the regulating function of the regulator and should put the generator at full output. Check voltage at the "A" terminal. If this voltage is above what you measure at the battery, the regulator is bad.
I am assuming you have good grounds everywhere, including the generator shell and the regulator.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
