Have you checked for fire to your sparkplugs while someone makes an attempt to start the engine with the ignition switch in the on position? If there's no fire when cranking. You need to watch the points while some cranks over the engine to see if the points are opening and closing. Could be the rubbing block is worn off if they're opening and closing. Set the rubbing block on your points to the high spot on one of the lobes in the distributor. Use a .020" feeler gauge to see if the points are too wide or are too close. You may need to open them or close them. You just can't look and think they're ok you need to check them. Once they're set at .020" move the engine so the points close then rub them with a point file or use some 320 wet or dry to clean them. Hal
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
