Posted by joe blow on December 23, 2009 at 12:12:53 from (74.220.14.47):
I have a 856 that will not move with a load. When I let out the clutch peddle the tractor does not move for a second or two, then it will drive ok with no load. I put a new clutch in, I changed the trans filter, and I changed mcv pump(where I got the pump they only had the gasket to mount the mcv valve to the trans, so I did not take the mcv totally apart, but I did pull some off the springs and they seemed to be fine) It is the same with the TA lever forward or back. I thought the TA would not slip in direct. I added 5 gal hyd, it is a little over full. I pulled the filter thinking I may have pluged right away, but It didn't look pluged. The oil probbably could be changed but I dont think that is the problem. Any help will be appreciated.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
