Re: IHC 454 front loader capacity
Posted by peter123 on December 26, 2009 at 13:48:37 from (84.1.103.178):
In Reply to: Re: IHC 454 front loader capacity posted by jimb2 on December 26, 2009 at 06:51:28:
Thanks for the response, I still have a problem which is that I have some 500Kg hay bails that need to be moved. should my remaining working 454 be capable of lifting this and would it help if I put one bail on the back first, the idea being that a counter balance on the back would reduce the load on the front axel.
By the way the broken 454 has the type of loader which has a heavey plate (about 3/8in thick) joining the rear mount and the front frame and I suspect this helps hold the tractor together. The other loader does not have this type of construction.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
