Red mist is correct on the FBK. If you need some useless trivia info the diesel version was FDBK ######
Your hood will probably have an extra small hole in front of the gas tank opening. This 7/8(?) gallon tank was for good gas while distallate was stored in the big tank. You would start on the good gas and then run on the distallate. It had less power, but it was really cheap. Other indicators of a former distallate tractor include a heat regulating manifold. Not sure if that is what it is really called, but it had a lever thing on the side that you could control the manifold heat with. They also came with radiator shutters to make the tractor run hotter. I guess they needed to be good and warm to burn the junk fuel.
Do some research on it and you will find a lot of info.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
