Posted by garyandnancy on December 28, 2009 at 09:10:16 from (64.136.26.230):
I’m working on a neighbor’s cub that will not start, and I’m stumped. When I crank it, it will sputter a bit, sounds like on all four cylinders, but will not run. Here is what I have done: -Compression on each cylinder is between 90 and 110 -Points are opening just as #1 cylinder is at TDC. I confirmed this with a multi tester. -Using a timing light, I have confirmed that #1 is getting spark just right at TDC -Plug wires are correctly connected, 1 – 3 – 4 -2 -I took the carburetor apart, passages are clean, all right parts are there. -I checked for a vacuum leak on the manifold, was not able to find any problem.
It seems like it should run, clearly I am missing some thing that is messing things up. Any ideas?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
